Skip To Main Content
Account
Settings
Logout
placeholder
Account
Settings
Logout
Filter:
All Files
Submit Search
About TDN
Using the TDN Portal
Supporting the TDN App
Supported Interface Devices
Installing the TDN App
Initial Device Setup (Apple iOS)
Initial Device Setup (Android)
User Interface
Account Creation and Configuration
Reading and Writing Tunes
Data Logging
Generating a Data Log
Sending Log Files to a Tuner
Deleting Unwanted Log Files
Adding a Description to a Log File
Reading Diagnostic Trouble Codes
The Setup / Tools Menu
Supported Controllers
Customer Support
Home >
If desired, the customer can add a description to a log file by doing the following:
Tap the log file to which to which a description is to be added.
Tap
EDIT
Enter the description.
Tap
OK
